MSI
Pure Wings 2
MEG Silent Gale P12
27.5 mm
93 g
209 g
300 U/min
1500 U/min
0.7 W
1.4 W
51.4 CFM
56.2 CFM
95.5 m³/h
1.25 mmH2O
2.21 mmH2O
20.2 dBA
22.7 dBA
5.5 V
4.3 V
202 U/min
906 U/min
324 U/min
742 U/min
194 U/min
186 U/min
1488 U/min
1980 U/min
512 U/min
31.5 CFM
+1.1 %
31.1 CFM
22.1 CFM
+2.5 %
21.5 CFM
21.3 CFM
+3.6 %
22.1 CFM
20.8 CFM
+5.8 %
19.7 CFM
53.5 m³/h
+1.1 %
52.9 m³/h
37.5 m³/h
+2.5 %
36.6 m³/h
36.2 m³/h
+3.6 %
37.5 m³/h
35.4 m³/h
+6.0 %
33.4 m³/h
+28.2 %
0.91 mmH2O
+14.1 %
+62.0 %
+62.0 %
+28.6 %
0.09 hPa
+14.3 %
+60.0 %
+60.0 %
38.2
-18.3 %
31.2
36.7
-5.2 %
34.8
36
-3.9 %
34.6
36.2
-8.6 %
33.1
