Pure Wings 2
Silent Wings 3
93 g
137 g
300 U/min
150 U/min
1500 U/min
1450 U/min
51.4 CFM
50.5 CFM
85.8 m³/h
1.25 mmH2O
1.79 mmH2O
20.2 dBA
16.4 dBA
4.1 V
3.9 V
202 U/min
324 U/min
206 U/min
244 U/min
1488 U/min
1411 U/min
31.5 CFM
+39.7 %
22.5 CFM
22.1 CFM
+11.0 %
19.9 CFM
21.3 CFM
+23.5 %
17.2 CFM
20.8 CFM
+24.2 %
16.8 CFM
53.5 m³/h
+39.7 %
38.3 m³/h
37.5 m³/h
+10.9 %
33.8 m³/h
36.2 m³/h
+23.5 %
29.3 m³/h
35.4 m³/h
+24.2 %
28.5 m³/h
+42.3 %
1.01 mmH2O
0.71
0.71
+42.0 %
0.5
0.5
+41.5 %
+0.5 %
+39.3 %
+2.0 %
38.2
-3.7 %
36.8
36.7
-12.2 %
41.8
36
-11.1 %
40.5
36.2
-10.8 %
40.6
