Corsair
Pure Wings 2
LL140 RGB
93 g
210 g
300 U/min
600 U/min
1500 U/min
1300 U/min
51.4 CFM
51.5 CFM
87.5 m³/h
1.25 mmH2O
1.52 mmH2O
20.2 dBA
25.0 dBA
Halbtransparent
2.9 V
202 U/min
226 U/min
324 U/min
378 U/min
1488 U/min
1319 U/min
31.5 CFM
+43.0 %
45.0 CFM
22.1 CFM
+28.5 %
28.4 CFM
21.3 CFM
+15.0 %
24.5 CFM
20.8 CFM
+26.9 %
26.4 CFM
53.5 m³/h
+43.0 %
76.5 m³/h
37.5 m³/h
+28.5 %
48.2 m³/h
36.2 m³/h
+14.9 %
41.6 m³/h
35.4 m³/h
+26.8 %
44.9 m³/h
+18.3 %
0.60 mmH2O
+42.0 %
0.5
0.5
+22.0 %
+16.7 %
+40.0 %
0.05
0.05
+20.0 %
38.2
-7.6 %
35.3
36.7
-0.5 %
36.9
36
-5.6 %
34
36.2
-3.9 %
34.8
