Thermalright
Cooler Master
TL-B12 Extreme
Masterfan MF120 Halo
25.6 mm
215 g
180 g
550 U/min
650 U/min
3150 U/min
1800 U/min
1.0 W
4.2 W
112.0 CFM
47.2 CFM
190.3 m³/h
5.00 mmH2O
40.5 dBA
30.0 dBA
Rot, Weiß
Grau
Halbtransparent
1.8 V
3.3 V
1.4 V
293 U/min
166 U/min
163 U/min
590 U/min
2857 U/min
1792 U/min
554 U/min
31.6 CFM
+27.6 %
24.8 CFM
23.7 CFM
+19.3 %
19.9 CFM
22.3 CFM
+10.2 %
20.2 CFM
21.1 CFM
+22.2 %
17.2 CFM
53.7 m³/h
+27.6 %
42.1 m³/h
40.3 m³/h
+19.2 %
33.8 m³/h
37.9 m³/h
+20.7 %
31.4 m³/h
35.8 m³/h
+22.2 %
29.3 m³/h
+77.5 %
0.40 mmH2O
+14.1 %
+102.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+75.0 %
+14.3 %
+100.0 %
+75.0 %
32.4
-14.3 %
37.8
31.1
-14.6 %
36.4
32.5
-11.0 %
36.5
30.5
-14.3 %
35.6
  • 163
  • 363
  • 563
  • 763
  • 963
  • 1163
  • 1363
  • 1563
  • 1763
  • 1963
  • 2163
  • 2363
  • 2563
  • 2763
