Corsair
Lian Li
ML 120 RGB Elite
UNI FAN SL-INF 120
186 g
210 g
450 U/min
2100 U/min
1.6 W
3.0 W
58.1 CFM
61.3 CFM
98.7 m³/h
104.1 m³/h
2.90 mmH2O
2.66 mmH2O
30.4 dBA
29.0 dBA
3.0 V
3.5 V
510 U/min
913 U/min
450 U/min
742 U/min
169 U/min
290 U/min
84 U/min
298 U/min
1993 U/min
2134 U/min
886 U/min
35.2 CFM
+17.7 %
30.0 CFM
24.2 CFM
+1.5 %
23.8 CFM
23.7 CFM
+10.1 %
21.5 CFM
21.3 CFM
+4.7 %
22.3 CFM
59.9 m³/h
+17.7 %
50.9 m³/h
41.1 m³/h
+1.5 %
40.5 m³/h
40.3 m³/h
+10.1 %
36.6 m³/h
36.2 m³/h
+4.7 %
37.9 m³/h
0.71
0.71
+16.4 %
+19.6 %
0.51 mmH2O
+39.2 %
0.51 mmH2O
+0.5 %
+16.0 %
+20.0 %
+40.0 %
28.5
-12.6 %
32.6
29.5
-11.9 %
33.5
28.5
-12.6 %
32.6
27.8
-17.0 %
33.5
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
