Fractal
Lian Li
Prisma AL-12PWM
UNI FAN SL120 ARGB
167 g
232 g
500 U/min
800 U/min
1900 U/min
1.9 W
85.7 CFM
58.5 CFM
145.7 m³/h
99.5 m³/h
2.80 mmH2O
1.67 mmH2O
32.0 dBA
31.0 dBA
Silber
4.5 V
3.8 V
2.4 V
443 U/min
412 U/min
269 U/min
98 U/min
2001 U/min
1828 U/min
550 U/min
31.6 CFM
+36.0 %
23.2 CFM
20.7 CFM
+16.9 %
17.7 CFM
20.8 CFM
+31.6 %
15.8 CFM
19.8 CFM
+29.2 %
15.3 CFM
53.7 m³/h
+35.9 %
39.5 m³/h
35.2 m³/h
+16.9 %
30.1 m³/h
35.4 m³/h
+31.6 %
26.9 m³/h
33.6 m³/h
+29.2 %
26.0 m³/h
+102.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+100.0 %
+75.0 %
+75.0 %
+50.0 %
35.5
-8.5 %
38.8
33.6
-8.4 %
36.7
31.9
-11.6 %
36.1
28.6
-17.3 %
34.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
