EK
Cooler Master
Vardar X3M D-RGB
Masterfan MF120 Halo
27.5 mm
210 g
180 g
500 U/min
650 U/min
2200 U/min
1800 U/min
2.2 W
67.0 CFM
47.2 CFM
114.0 m³/h
2.75 mmH2O
34.2 dBA
30.0 dBA
Grau
Halbtransparent
2.7 V
3.3 V
2.3 V
472 U/min
166 U/min
418 U/min
590 U/min
666 U/min
367 U/min
2161 U/min
1792 U/min
36.4 CFM
+47.1 %
24.8 CFM
21.8 CFM
+9.8 %
19.9 CFM
20.4 CFM
+0.6 %
20.2 CFM
19.2 CFM
+11.3 %
17.2 CFM
61.9 m³/h
+47.0 %
42.1 m³/h
37.1 m³/h
+9.8 %
33.8 m³/h
34.6 m³/h
+10.2 %
31.4 m³/h
32.6 m³/h
+11.3 %
29.3 m³/h
1.32 mmH2O
+230.0 %
0.40 mmH2O
+32.8 %
+25.0 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
0.13 hPa
+225.0 %
+33.3 %
+25.0 %
+50.0 %
29.9
-20.9 %
37.8
33.8
-7.1 %
36.4
28.3
-22.5 %
36.5
28.4
-20.2 %
35.6
  • 666
  • 866
  • 1066
  • 1266
  • 1466
  • 1666
  • 1866
  • 2066
