Corsair
Cooler Master
QL120 RGB
Masterfan MF120 Halo
163 g
180 g
500 U/min
650 U/min
1500 U/min
1800 U/min
41.8 CFM
47.2 CFM
1.55 mmH2O
26.0 dBA
30.0 dBA
Silber
Grau
Halbtransparent
Halbtransparent
3.0 V
3.3 V
245 U/min
166 U/min
472 U/min
590 U/min
1600 U/min
1792 U/min
27.8 CFM
+12.2 %
24.8 CFM
20.6 CFM
+3.6 %
19.9 CFM
19.2 CFM
+5.5 %
20.2 CFM
17.24
17.24
47.2 m³/h
+12.1 %
42.1 m³/h
35.0 m³/h
+3.6 %
33.8 m³/h
32.6 m³/h
+3.8 %
31.4 m³/h
29.3
29.3
1.01 mmH2O
+152.5 %
0.40 mmH2O
+62.0 %
+25.0 %
0.40 mmH2O
0.4
0.4
+150.0 %
+60.0 %
+25.0 %
0.04
0.04
38.4
-1.6 %
37.8
38.3
-5.0 %
36.4
35.9
-1.6 %
36.5
35.8
-0.6 %
35.6
