Corsair
QL120 RGB
Pure Wings 2
163 g
93 g
500 U/min
300 U/min
1500 U/min
1500 U/min
41.8 CFM
51.4 CFM
1.55 mmH2O
1.25 mmH2O
26.0 dBA
20.2 dBA
Silber
Halbtransparent
3.0 V
245 U/min
202 U/min
472 U/min
324 U/min
1600 U/min
1488 U/min
27.8 CFM
+13.3 %
31.5 CFM
20.6 CFM
+7.1 %
22.1 CFM
19.2 CFM
+11.1 %
21.3 CFM
17.2 CFM
+20.8 %
20.8 CFM
47.2 m³/h
+13.3 %
53.5 m³/h
35.0 m³/h
+7.1 %
37.5 m³/h
32.6 m³/h
+11.0 %
36.2 m³/h
29.3 m³/h
+20.8 %
35.4 m³/h
1.01 mmH2O
+42.3 %
+42.0 %
0.5
0.5
0.40 mmH2O
+25.0 %
+42.9 %
+40.0 %
0.05
0.05
+25.0 %
38.4
-0.5 %
38.2
38.3
-4.2 %
36.7
35.9
-0.3 %
36
35.8
-1.1 %
36.2
