Corsair
Alphacool
QL120 RGB
Eiszyklon Aurora Lux Pro ARGB
163 g
200 g
500 U/min
600 U/min
1500 U/min
1500 U/min
41.8 CFM
58.3 CFM
99.3 m³/h
1.55 mmH2O
1.60 mmH2O
26.0 dBA
38.0 dBA
Silber
Halbtransparent
3.0 V
3.3 V
2.9 V
245 U/min
316 U/min
472 U/min
393 U/min
1600 U/min
1499 U/min
27.8 CFM
+65.4 %
46.0 CFM
20.6 CFM
+20.2 %
24.8 CFM
19.2 CFM
+10.4 %
21.2 CFM
17.2 CFM
+40.0 %
24.1 CFM
47.2 m³/h
+65.5 %
78.1 m³/h
35.0 m³/h
+20.3 %
42.1 m³/h
32.6 m³/h
+10.4 %
36.0 m³/h
29.3 m³/h
+39.9 %
41.0 m³/h
1.01 mmH2O
+42.3 %
+25.0 %
0.40 mmH2O
0.5
0.5
0.4
0.4
+42.9 %
+25.0 %
0.05
0.05
0.04
0.04
38.4
-10.4 %
34.4
38.3
-11.0 %
34.1
35.9
-7.8 %
33.1
35.8
-9.2 %
32.5
