Corsair
Cooler Master
QL120 RGB
Sickleflow 140 ARGB
163 g
195 g
500 U/min
650 U/min
1500 U/min
1400 U/min
41.8 CFM
67.0 CFM
113.8 m³/h
1.55 mmH2O
2.25 mmH2O
26.0 dBA
27.0 dBA
Silber
Halbtransparent
Halbtransparent
3.0 V
5.5 V
2.9 V
245 U/min
599 U/min
472 U/min
495 U/min
1600 U/min
1374 U/min
27.8 CFM
+63.1 %
45.3 CFM
20.6 CFM
+36.3 %
28.1 CFM
19.2 CFM
+35.9 %
26.1 CFM
17.2 CFM
+56.7 %
27.0 CFM
47.2 m³/h
+63.1 %
77.0 m³/h
35.0 m³/h
+36.3 %
47.7 m³/h
32.6 m³/h
+35.9 %
44.3 m³/h
29.3 m³/h
+56.7 %
45.9 m³/h
1.01 mmH2O
+102.0 %
0.5
0.5
0.5
0.5
0.40 mmH2O
+25.0 %
+100.0 %
0.05
0.05
0.05
0.05
+25.0 %
38.4
-7.6 %
35.5
38.3
-2.9 %
37.2
35.9
-8.6 %
32.8
35.8
-6.4 %
33.5
