MSI
Fractal
MEG Silent Gale P12
Prisma AL-12PWM
27.5 mm
209 g
167 g
500 U/min
0.7 W
1.4 W
1.9 W
56.2 CFM
85.7 CFM
95.5 m³/h
145.7 m³/h
2.21 mmH2O
2.80 mmH2O
22.7 dBA
32.0 dBA
5.5 V
4.5 V
4.3 V
3.8 V
906 U/min
443 U/min
742 U/min
269 U/min
194 U/min
186 U/min
1980 U/min
2001 U/min
550 U/min
512 U/min
31.1 CFM
+1.5 %
31.6 CFM
21.5 CFM
+4.0 %
20.7 CFM
22.1 CFM
+6.0 %
20.8 CFM
19.7 CFM
+0.5 %
19.8 CFM
52.9 m³/h
+1.5 %
53.7 m³/h
36.6 m³/h
+4.0 %
35.2 m³/h
37.5 m³/h
+5.9 %
35.4 m³/h
33.4 m³/h
+0.6 %
33.6 m³/h
0.91 mmH2O
+12.3 %
+14.1 %
+14.1 %
+32.8 %
0.09 hPa
+12.5 %
+14.3 %
+14.3 %
+33.3 %
31.2
-12.1 %
35.5
34.8
-3.4 %
33.6
34.6
-7.8 %
31.9
33.1
-13.6 %
28.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
