MSI
MEG Silent Gale P12
Light Wings 140 PWM HS
27.5 mm
209 g
266 g
250 U/min
2200 U/min
0.7 W
1.9 W
1.4 W
4.7 W
56.2 CFM
71.7 CFM
95.5 m³/h
121.8 m³/h
2.21 mmH2O
2.30 mmH2O
22.7 dBA
31.0 dBA
5.5 V
3.0 V
4.3 V
906 U/min
565 U/min
742 U/min
556 U/min
194 U/min
186 U/min
1980 U/min
2264 U/min
241 U/min
512 U/min
31.1 CFM
+28.9 %
40.1 CFM
21.5 CFM
+13.4 %
24.4 CFM
22.1 CFM
+1.9 %
22.5 CFM
19.7 CFM
+22.6 %
24.1 CFM
52.9 m³/h
+28.9 %
68.2 m³/h
36.6 m³/h
+13.4 %
41.5 m³/h
37.5 m³/h
+1.9 %
38.2 m³/h
33.4 m³/h
+22.8 %
41.0 m³/h
0.91 mmH2O
+101.1 %
1.83 mmH2O
+32.8 %
+32.8 %
+32.8 %
0.09 hPa
+100.0 %
0.18 hPa
+33.3 %
+33.3 %
+33.3 %
31.2
-18.3 %
25.5
34.8
-23.3 %
26.7
34.6
-25.7 %
25.7
33.1
-23.0 %
25.5
  • 556
  • 756
  • 956
  • 1156
  • 1356
  • 1556
  • 1756
  • 1956
  • 2156
