MSI
MEG Silent Gale P12
Light Wings PWM
27.5 mm
209 g
205 g
100 U/min
1700 U/min
0.7 W
0.8 W
1.4 W
4.6 W
56.2 CFM
41.5 CFM
95.5 m³/h
70.5 m³/h
2.21 mmH2O
1.66 mmH2O
22.7 dBA
20.6 dBA
5.5 V
4.3 V
906 U/min
369 U/min
742 U/min
350 U/min
194 U/min
186 U/min
1980 U/min
1680 U/min
134 U/min
512 U/min
31.1 CFM
+8.5 %
33.8 CFM
21.5 CFM
+8.3 %
19.9 CFM
22.1 CFM
+13.6 %
19.4 CFM
19.7 CFM
+6.5 %
18.5 CFM
52.9 m³/h
+8.5 %
57.4 m³/h
36.6 m³/h
+8.3 %
33.8 m³/h
37.5 m³/h
+13.6 %
33.0 m³/h
33.4 m³/h
+6.4 %
31.4 m³/h
0.91 mmH2O
+28.2 %
+62.0 %
+62.0 %
+32.8 %
0.09 hPa
+28.6 %
+60.0 %
+60.0 %
+33.3 %
31.2
-5.4 %
29.5
34.8
-14.9 %
29.6
34.6
-9.0 %
31.5
33.1
-2.1 %
32.4
  • 350
  • 550
  • 750
  • 950
  • 1150
  • 1350
  • 1550
