Asus
Arctic
P12 PWM PST RGB 0dB
145 g
159 g
250 U/min
1800 U/min
62.5 CFM
48.8 CFM
106.2 m³/h
82.9 m³/h
3.07 mmH2O
1.85 mmH2O
22.5 dBA
Grau
Halbtransparent
4.0 V
2.9 V
409 U/min
380 U/min
419 U/min
532 U/min
208 U/min
129 U/min
1778 U/min
1985 U/min
308 U/min
23.9 CFM
+34.2 %
32.1 CFM
18.7 CFM
+28.0 %
23.9 CFM
18.5 CFM
+24.5 %
23.0 CFM
17.7 CFM
+24.6 %
22.1 CFM
40.7 m³/h
+34.1 %
54.6 m³/h
31.8 m³/h
+28.0 %
40.7 m³/h
31.4 m³/h
+24.5 %
39.1 m³/h
30.1 m³/h
+24.6 %
37.5 m³/h
0.92 mmH2O
+13.3 %
0.92 mmH2O
+50.5 %
0.82 mmH2O
+33.7 %
+17.0 %
0.09 hPa
+12.5 %
0.09 hPa
+50.0 %
+33.3 %
+16.7 %
34.6
-2.3 %
33.8
38.9
-18.8 %
31.6
38.4
-14.8 %
32.7
38.4
-16.4 %
32.1
