Blacknoise
Arctic
NB-eLoop X PWM B12xP ARGB
P12 PWM PST RGB 0dB
120 g
159 g
400 U/min
77.9 CFM
48.8 CFM
132.4 m³/h
82.9 m³/h
3.02 mmH2O
1.85 mmH2O
28.4 dBA
Grau
Grau
Halbtransparent
3.4 V
4.0 V
2.9 V
294 U/min
380 U/min
138 U/min
532 U/min
2002 U/min
1985 U/min
40.5 CFM
+26.2 %
32.1 CFM
24.9 CFM
+3.9 %
23.9 CFM
23.01
23.01
21.0 CFM
+5.0 %
22.1 CFM
68.9 m³/h
+26.2 %
54.6 m³/h
42.3 m³/h
+4.0 %
40.7 m³/h
39.1 m³/h
+0.0 %
39.1 m³/h
35.7 m³/h
+5.0 %
37.5 m³/h
1.43 mmH2O
+76.5 %
+32.8 %
0.61
0.61
+22.0 %
0.14 hPa
+75.0 %
+33.3 %
0.06
0.06
+20.0 %
34.4
-1.7 %
33.8
36.5
-13.4 %
31.6
35.9
-8.9 %
32.7
36.1
-11.1 %
32.1
