Blacknoise
Arctic
NB-eLoop X PWM B12xP ARGB
P12 PWM
120 g
139 g
400 U/min
200 U/min
1800 U/min
77.9 CFM
56.3 CFM
132.4 m³/h
3.02 mmH2O
2.20 mmH2O
28.4 dBA
Grau
Silber
3.4 V
3.0 V
294 U/min
207 U/min
138 U/min
547 U/min
2002 U/min
1748 U/min
40.5 CFM
+20.9 %
33.5 CFM
24.9 CFM
+7.1 %
23.2 CFM
23.01
23.01
21.0 CFM
+2.5 %
21.5 CFM
68.9 m³/h
+20.9 %
57.0 m³/h
42.3 m³/h
+7.1 %
39.5 m³/h
39.1
39.1
35.7 m³/h
+2.5 %
36.6 m³/h
1.43 mmH2O
+186.0 %
+32.8 %
+22.0 %
+22.0 %
0.14 hPa
+180.0 %
+33.3 %
+20.0 %
+20.0 %
34.4
-6.3 %
36.7
36.5
-4.9 %
34.7
35.9
-3.3 %
34.7
36.1
-4.7 %
34.4
