Blacknoise
Cooler Master
NB-eLoop X PWM B12xP ARGB
Masterfan MF120 Halo
120 g
180 g
400 U/min
650 U/min
1800 U/min
77.9 CFM
47.2 CFM
132.4 m³/h
3.02 mmH2O
28.4 dBA
30.0 dBA
Grau
Grau
Halbtransparent
3.4 V
3.3 V
294 U/min
166 U/min
138 U/min
590 U/min
2002 U/min
1792 U/min
40.5 CFM
+63.7 %
24.8 CFM
24.9 CFM
+25.1 %
19.9 CFM
23.0 CFM
+13.7 %
20.2 CFM
21.0 CFM
+21.9 %
17.2 CFM
68.9 m³/h
+63.7 %
42.1 m³/h
42.3 m³/h
+25.1 %
33.8 m³/h
39.1 m³/h
+24.5 %
31.4 m³/h
35.7 m³/h
+21.8 %
29.3 m³/h
1.43 mmH2O
+257.5 %
0.40 mmH2O
0.81
0.81
+52.5 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
0.14 hPa
+250.0 %
0.08
0.08
+50.0 %
+25.0 %
34.4
-9.0 %
37.8
36.5
-0.3 %
36.4
35.9
-1.6 %
36.5
36.1
-1.4 %
35.6
