Blacknoise
NB-eLoop X PWM B12xP ARGB
Light Wings PWM HS
120 g
210 g
400 U/min
300 U/min
2500 U/min
1.4 W
5.4 W
77.9 CFM
52.3 CFM
132.4 m³/h
88.9 m³/h
3.02 mmH2O
2.60 mmH2O
28.4 dBA
31.0 dBA
Grau
3.4 V
294 U/min
608 U/min
138 U/min
565 U/min
2002 U/min
2489 U/min
248 U/min
40.5 CFM
+24.6 %
32.5 CFM
24.9 CFM
+34.7 %
18.5 CFM
23.0 CFM
+21.4 %
18.9 CFM
21.0 CFM
+18.6 %
17.7 CFM
68.9 m³/h
+24.6 %
55.3 m³/h
42.3 m³/h
+34.7 %
31.4 m³/h
39.1 m³/h
+21.4 %
32.2 m³/h
35.7 m³/h
+18.6 %
30.1 m³/h
1.43 mmH2O
+101.4 %
+62.0 %
+52.5 %
0.40 mmH2O
0.5
0.5
0.14 hPa
+100.0 %
+60.0 %
+50.0 %
0.05
0.05
34.4
-2.0 %
33.7
36.5
-13.4 %
31.6
35.9
-10.9 %
32
36.1
-15.0 %
30.7
  • 565
  • 765
  • 965
  • 1165
  • 1365
  • 1565
  • 1765
  • 1965
  • 2165
  • 2365
