Blacknoise
Alphacool
NB-eLoop X PWM B12xP ARGB
Rise Aurora
120 g
400 U/min
6.6 W
77.9 CFM
90.7 CFM
132.4 m³/h
154.1 m³/h
3.02 mmH2O
2.20 mmH2O
28.4 dBA
38.4 dBA
Grau
3.4 V
2.9 V
294 U/min
883 U/min
138 U/min
553 U/min
331 U/min
145 U/min
2002 U/min
2108 U/min
677 U/min
40.5 CFM
+24.2 %
50.4 CFM
24.9 CFM
+7.1 %
26.7 CFM
23.0 CFM
+5.4 %
21.8 CFM
21.0 CFM
+2.3 %
20.5 CFM
68.9 m³/h
+24.2 %
85.6 m³/h
42.3 m³/h
+7.1 %
45.3 m³/h
39.1 m³/h
+5.4 %
37.1 m³/h
35.7 m³/h
+2.3 %
34.9 m³/h
1.43 mmH2O
+41.6 %
1.01 mmH2O
+35.0 %
0.60 mmH2O
+16.4 %
+62.0 %
0.14 hPa
+40.0 %
+33.3 %
+16.7 %
+60.0 %
34.4
-12.7 %
39.4
36.5
-6.9 %
39.2
35.9
-7.9 %
39
36.1
-4.2 %
37.7
  • 331
  • 531
  • 731
  • 931
  • 1131
  • 1331
  • 1531
  • 1731
  • 1931
