Blacknoise
Alpenföhn
NB-eLoop X PWM B12xP ARGB
Wing Boost 3
120 g
122 g
400 U/min
400 U/min
1050 U/min
77.9 CFM
60.6 CFM
132.4 m³/h
103.0 m³/h
3.02 mmH2O
28.4 dBA
22.0 dBA
Grau
3.4 V
4.7 V
2.0 V
294 U/min
443 U/min
138 U/min
174 U/min
2002 U/min
1075 U/min
477 U/min
40.5 CFM
+21.5 %
49.3 CFM
24.9 CFM
+6.0 %
23.5 CFM
23.0 CFM
+2.1 %
23.5 CFM
21.0 CFM
+1.7 %
20.7 CFM
68.9 m³/h
+21.5 %
83.7 m³/h
42.3 m³/h
+6.0 %
39.9 m³/h
39.1 m³/h
+2.0 %
39.9 m³/h
35.7 m³/h
+1.7 %
35.1 m³/h
1.43 mmH2O
+14.0 %
1.63 mmH2O
+32.8 %
+22.0 %
+25.0 %
0.40 mmH2O
0.14 hPa
+14.3 %
0.16 hPa
+33.3 %
+20.0 %
+25.0 %
34.4
-22.9 %
44.6
36.5
-22.8 %
47.3
35.9
-21.4 %
45.7
36.1
-16.6 %
43.3
