Blacknoise
Lian Li
NB-eLoop X PWM B12xP ARGB
UNI FAN SL120 ARGB
120 g
232 g
400 U/min
800 U/min
1900 U/min
77.9 CFM
58.5 CFM
132.4 m³/h
99.5 m³/h
3.02 mmH2O
1.67 mmH2O
28.4 dBA
31.0 dBA
Grau
Silber
3.4 V
2.4 V
294 U/min
412 U/min
138 U/min
98 U/min
2002 U/min
1828 U/min
40.5 CFM
+74.5 %
23.2 CFM
24.9 CFM
+40.5 %
17.7 CFM
23.0 CFM
+45.4 %
15.8 CFM
21.0 CFM
+37.3 %
15.3 CFM
68.9 m³/h
+74.4 %
39.5 m³/h
42.3 m³/h
+40.5 %
30.1 m³/h
39.1 m³/h
+45.4 %
26.9 m³/h
35.7 m³/h
+37.3 %
26.0 m³/h
1.43 mmH2O
+257.5 %
0.40 mmH2O
+102.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
0.14 hPa
+250.0 %
+100.0 %
+50.0 %
+25.0 %
34.4
-11.3 %
38.8
36.5
-0.5 %
36.7
35.9
-0.6 %
36.1
36.1
-4.2 %
34.6
