Blacknoise
Corsair
NB-eLoop X PWM B12xP ARGB
LL140 RGB
120 g
210 g
400 U/min
600 U/min
1300 U/min
77.9 CFM
51.5 CFM
132.4 m³/h
87.5 m³/h
3.02 mmH2O
1.52 mmH2O
28.4 dBA
25.0 dBA
Grau
Halbtransparent
3.4 V
2.9 V
294 U/min
226 U/min
138 U/min
378 U/min
2002 U/min
1319 U/min
40.5 CFM
+11.0 %
45.0 CFM
24.9 CFM
+14.0 %
28.4 CFM
23.0 CFM
+6.4 %
24.5 CFM
21.0 CFM
+25.8 %
26.4 CFM
68.9 m³/h
+11.0 %
76.5 m³/h
42.3 m³/h
+13.9 %
48.2 m³/h
39.1 m³/h
+6.4 %
41.6 m³/h
35.7 m³/h
+25.8 %
44.9 m³/h
1.43 mmH2O
+138.3 %
0.60 mmH2O
+62.0 %
+22.0 %
+22.0 %
0.14 hPa
+133.3 %
+60.0 %
+20.0 %
+20.0 %
34.4
-2.5 %
35.3
36.5
-1.1 %
36.9
35.9
-5.3 %
34
36.1
-3.6 %
34.8
