Blacknoise
Blacknoise
NB-eLoop X PWM B12xP ARGB
B14x-P-BL PWM ARGB
120 g
202 g
400 U/min
1500 U/min
0.5 W
2.9 W
77.9 CFM
110.0 CFM
132.4 m³/h
186.0 m³/h
3.02 mmH2O
2.30 mmH2O
28.4 dBA
29.6 dBA
Grau
3.4 V
4.3 V
294 U/min
335 U/min
138 U/min
154 U/min
2002 U/min
1487 U/min
40.5 CFM
+48.6 %
60.3 CFM
24.9 CFM
+33.6 %
33.2 CFM
23.0 CFM
+40.4 %
32.3 CFM
21.0 CFM
+58.3 %
33.2 CFM
68.9 m³/h
+48.6 %
102.4 m³/h
42.3 m³/h
+33.6 %
56.5 m³/h
39.1 m³/h
+40.4 %
54.9 m³/h
35.7 m³/h
+58.3 %
56.5 m³/h
1.43 mmH2O
+8.3 %
1.32 mmH2O
+63.0 %
1.32 mmH2O
+65.6 %
1.01 mmH2O
+144.0 %
1.22 mmH2O
0.14 hPa
+7.7 %
0.13 hPa
+62.5 %
0.13 hPa
+66.7 %
+140.0 %
0.12 hPa
34.4
-2.0 %
33.7
36.5
-2.4 %
37.4
35.9
-1.9 %
36.6
36.1
-0.3 %
36
