Blacknoise
Cooler Master
NB-eLoop X PWM B12xP ARGB
Sickleflow 140 ARGB
120 g
195 g
400 U/min
650 U/min
1400 U/min
77.9 CFM
67.0 CFM
132.4 m³/h
113.8 m³/h
3.02 mmH2O
2.25 mmH2O
28.4 dBA
27.0 dBA
Grau
Halbtransparent
3.4 V
5.5 V
2.9 V
294 U/min
599 U/min
138 U/min
495 U/min
2002 U/min
1374 U/min
40.5 CFM
+11.8 %
45.3 CFM
24.9 CFM
+12.8 %
28.1 CFM
23.0 CFM
+13.3 %
26.1 CFM
21.0 CFM
+28.6 %
27.0 CFM
68.9 m³/h
+11.8 %
77.0 m³/h
42.3 m³/h
+12.8 %
47.7 m³/h
39.1 m³/h
+13.3 %
44.3 m³/h
35.7 m³/h
+28.6 %
45.9 m³/h
1.43 mmH2O
+186.0 %
+62.0 %
+22.0 %
0.5
0.5
0.14 hPa
+180.0 %
+60.0 %
+20.0 %
0.05
0.05
34.4
-3.1 %
35.5
36.5
-1.9 %
37.2
35.9
-8.6 %
32.8
36.1
-7.2 %
33.5
