Blacknoise
Noctua
NB-eLoop X PWM B12xP ARGB
NF-A14 FLX
120 g
210 g
400 U/min
900 U/min
1200 U/min
77.9 CFM
68.0 CFM
132.4 m³/h
115.5 m³/h
3.02 mmH2O
1.51 mmH2O
28.4 dBA
19.2 dBA
Beige
Grau
Braun
Braun
3.4 V
4.6 V
4.2 V
294 U/min
381 U/min
138 U/min
469 U/min
2002 U/min
1199 U/min
40.5 CFM
+31.9 %
53.5 CFM
24.9 CFM
+32.4 %
33.0 CFM
23.0 CFM
+37.6 %
31.7 CFM
21.0 CFM
+43.4 %
30.1 CFM
68.9 m³/h
+31.9 %
90.9 m³/h
42.3 m³/h
+32.4 %
56.0 m³/h
39.1 m³/h
+37.6 %
53.8 m³/h
35.7 m³/h
+43.4 %
51.2 m³/h
1.43 mmH2O
+57.1 %
0.91 mmH2O
+12.3 %
0.91 mmH2O
+22.0 %
+66.7 %
0.30 mmH2O
0.14 hPa
+55.6 %
0.09 hPa
+12.5 %
0.09 hPa
+20.0 %
+66.7 %
0.03 hPa
34.4
-0.6 %
34.2
36.5
-14.3 %
42.6
35.9
-12.0 %
40.8
36.1
-9.5 %
39.9
