Alphacool
Sharkoon
Rise Aurora
Silent Storm PWM RGB Fan
180 g
168 g
400 U/min
2500 U/min
1400 U/min
2.6 W
70.0 CFM
118.9 m³/h
121.9 m³/h
3.17 mmH2O
1.47 mmH2O
31.5 dBA
34.7 dBA
3.0 V
2.9 V
1.9 V
862 U/min
506 U/min
874 U/min
54 U/min
339 U/min
181 U/min
2775 U/min
1413 U/min
440 U/min
1045 U/min
29.0 CFM
+41.6 %
41.1 CFM
24.4 CFM
+30.8 %
31.9 CFM
23.5 CFM
+30.6 %
30.7 CFM
22.1 CFM
+52.2 %
33.6 CFM
49.3 m³/h
+41.6 %
69.8 m³/h
41.5 m³/h
+30.8 %
54.3 m³/h
39.9 m³/h
+30.6 %
52.1 m³/h
37.5 m³/h
+52.3 %
57.1 m³/h
+32.4 %
0.51 mmH2O
+39.3 %
0.41 mmH2O
+74.1 %
0.41 mmH2O
+25.0 %
0.51 mmH2O
+33.3 %
+40.0 %
+75.0 %
+25.0 %
41.6
-21.6 %
32.6
41
-20.2 %
32.7
39.1
-15.1 %
33.2
40.5
-20.7 %
32.1
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
