Lian Li
Lian Li
UNI FAN SL120 ARGB
Uni Fan AL V2 120
28 mm
232 g
240 g
800 U/min
250 U/min
1900 U/min
0.7 W
2.1 W
58.5 CFM
77.3 CFM
99.5 m³/h
131.3 m³/h
1.67 mmH2O
2.97 mmH2O
31.0 dBA
28.7 dBA
Einzelreview
Silber
3.0 V
2.4 V
412 U/min
762 U/min
98 U/min
749 U/min
297 U/min
198 U/min
1828 U/min
820 U/min
23.2 CFM
+107.4 %
48.2 CFM
17.7 CFM
+127.0 %
40.2 CFM
15.8 CFM
+90.1 %
30.1 CFM
15.3 CFM
+169.3 %
41.2 CFM
39.5 m³/h
+107.3 %
81.9 m³/h
30.1 m³/h
+126.9 %
68.3 m³/h
26.9 m³/h
+90.1 %
51.1 m³/h
26.0 m³/h
+169.2 %
70.0 m³/h
0.40 mmH2O
+333.4 %
1.73 mmH2O
0.40 mmH2O
+282.5 %
1.53 mmH2O
0.40 mmH2O
+155.0 %
1.02 mmH2O
0.40 mmH2O
+307.5 %
1.63 mmH2O
+325.0 %
0.17 hPa
+275.0 %
0.15 hPa
+150.0 %
+300.0 %
0.16 hPa
38.8
-18.8 %
31.5
36.7
-20.7 %
29.1
36.1
-15.5 %
30.5
34.6
-13.0 %
30.1
  • 297
  • 497
  • 697
  • 897
  • 1097
  • 1297
  • 1497
  • 1697
  • 1897
