Lian Li
Fractal
UNI FAN SL120 ARGB
Prisma AL-12PWM
232 g
167 g
800 U/min
500 U/min
1900 U/min
1.9 W
58.5 CFM
85.7 CFM
99.5 m³/h
145.7 m³/h
1.67 mmH2O
2.80 mmH2O
31.0 dBA
32.0 dBA
Silber
4.5 V
2.4 V
3.8 V
412 U/min
443 U/min
98 U/min
269 U/min
1828 U/min
2001 U/min
550 U/min
23.2 CFM
+36.0 %
31.6 CFM
17.7 CFM
+16.9 %
20.7 CFM
15.8 CFM
+31.6 %
20.8 CFM
15.3 CFM
+29.2 %
19.8 CFM
39.5 m³/h
+35.9 %
53.7 m³/h
30.1 m³/h
+16.9 %
35.2 m³/h
26.9 m³/h
+31.6 %
35.4 m³/h
26.0 m³/h
+29.2 %
33.6 m³/h
0.40 mmH2O
+102.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+52.5 %
+100.0 %
+75.0 %
+75.0 %
+50.0 %
38.8
-8.5 %
35.5
36.7
-8.4 %
33.6
36.1
-11.6 %
31.9
34.6
-17.3 %
28.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
