Lian Li
UNI FAN SL120 ARGB
Light Wings 140 PWM HS
232 g
266 g
800 U/min
250 U/min
1900 U/min
2200 U/min
1.9 W
4.7 W
58.5 CFM
71.7 CFM
99.5 m³/h
121.8 m³/h
1.67 mmH2O
2.30 mmH2O
31.0 dBA
31.0 dBA
Silber
3.0 V
2.4 V
412 U/min
565 U/min
98 U/min
556 U/min
1828 U/min
2264 U/min
241 U/min
23.2 CFM
+72.7 %
40.1 CFM
17.7 CFM
+37.9 %
24.4 CFM
15.8 CFM
+42.0 %
22.5 CFM
15.3 CFM
+57.7 %
24.1 CFM
39.5 m³/h
+72.7 %
68.2 m³/h
30.1 m³/h
+37.9 %
41.5 m³/h
26.9 m³/h
+42.0 %
38.2 m³/h
26.0 m³/h
+57.7 %
41.0 m³/h
0.40 mmH2O
+357.5 %
1.83 mmH2O
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
+350.0 %
0.18 hPa
+50.0 %
+50.0 %
+50.0 %
38.8
-34.3 %
25.5
36.7
-27.2 %
26.7
36.1
-28.8 %
25.7
34.6
-26.3 %
25.5
  • 556
  • 756
  • 956
  • 1156
  • 1356
  • 1556
  • 1756
  • 1956
  • 2156
