Lian Li
Alphacool
UNI FAN SL120 ARGB
Rise Aurora
232 g
180 g
800 U/min
1900 U/min
2500 U/min
58.5 CFM
70.0 CFM
99.5 m³/h
118.9 m³/h
1.67 mmH2O
3.17 mmH2O
31.0 dBA
31.5 dBA
Silber
3.0 V
2.4 V
2.9 V
412 U/min
862 U/min
98 U/min
874 U/min
339 U/min
181 U/min
1828 U/min
2775 U/min
1045 U/min
23.2 CFM
+24.8 %
29.0 CFM
17.7 CFM
+37.9 %
24.4 CFM
15.8 CFM
+48.3 %
23.5 CFM
15.3 CFM
+44.2 %
22.1 CFM
39.5 m³/h
+24.8 %
49.3 m³/h
30.1 m³/h
+37.9 %
41.5 m³/h
26.9 m³/h
+48.3 %
39.9 m³/h
26.0 m³/h
+44.2 %
37.5 m³/h
0.40 mmH2O
+53.0 %
0.40 mmH2O
+27.5 %
0.51 mmH2O
0.40 mmH2O
+2.0 %
0.41 mmH2O
0.40 mmH2O
+2.0 %
0.41 mmH2O
+50.0 %
+25.0 %
0.04
0.04
0.04
0.04
38.8
-6.7 %
41.6
36.7
-10.5 %
41
36.1
-7.7 %
39.1
34.6
-14.6 %
40.5
