Lian Li
Arctic
UNI FAN SL120 ARGB
P12 PWM PST RGB 0dB
232 g
159 g
800 U/min
1900 U/min
58.5 CFM
48.8 CFM
99.5 m³/h
82.9 m³/h
1.67 mmH2O
1.85 mmH2O
31.0 dBA
Silber
Grau
Halbtransparent
4.0 V
2.4 V
2.9 V
412 U/min
380 U/min
98 U/min
532 U/min
1828 U/min
1985 U/min
23.2 CFM
+38.3 %
32.1 CFM
17.7 CFM
+35.2 %
23.9 CFM
15.8 CFM
+45.4 %
23.0 CFM
15.3 CFM
+44.2 %
22.1 CFM
39.5 m³/h
+38.2 %
54.6 m³/h
30.1 m³/h
+35.2 %
40.7 m³/h
26.9 m³/h
+45.3 %
39.1 m³/h
26.0 m³/h
+44.2 %
37.5 m³/h
0.40 mmH2O
+102.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
+100.0 %
+50.0 %
+50.0 %
+50.0 %
38.8
-12.9 %
33.8
36.7
-13.9 %
31.6
36.1
-9.4 %
32.7
34.6
-7.2 %
32.1
