Lian Li
UNI FAN SL120 ARGB
Pure Wings 2
232 g
93 g
800 U/min
300 U/min
1900 U/min
1500 U/min
58.5 CFM
51.4 CFM
99.5 m³/h
1.67 mmH2O
1.25 mmH2O
31.0 dBA
20.2 dBA
Silber
2.4 V
412 U/min
202 U/min
98 U/min
324 U/min
1828 U/min
1488 U/min
23.2 CFM
+35.5 %
31.5 CFM
17.7 CFM
+24.6 %
22.1 CFM
15.8 CFM
+34.6 %
21.3 CFM
15.3 CFM
+36.1 %
20.8 CFM
39.5 m³/h
+35.4 %
53.5 m³/h
30.1 m³/h
+24.6 %
37.5 m³/h
26.9 m³/h
+34.6 %
36.2 m³/h
26.0 m³/h
+36.2 %
35.4 m³/h
0.40 mmH2O
+77.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
+75.0 %
+75.0 %
+25.0 %
+25.0 %
38.8
-1.5 %
38.2
36.7
36.7
36.1
-0.3 %
36
34.6
-4.4 %
36.2
