Arctic
Lian Li
P14 PWM
UNI FAN SL120 ARGB
194 g
232 g
200 U/min
800 U/min
1700 U/min
1900 U/min
72.8 CFM
58.5 CFM
123.8 m³/h
99.5 m³/h
2.40 mmH2O
1.67 mmH2O
31.0 dBA
Silber
3.8 V
2.4 V
395 U/min
412 U/min
481 U/min
98 U/min
1733 U/min
1828 U/min
45.7 CFM
+96.5 %
23.2 CFM
27.1 CFM
+52.9 %
17.7 CFM
25.8 CFM
+62.8 %
15.8 CFM
27.0 CFM
+76.5 %
15.3 CFM
77.6 m³/h
+96.5 %
39.5 m³/h
46.0 m³/h
+52.8 %
30.1 m³/h
43.8 m³/h
+62.8 %
26.9 m³/h
45.9 m³/h
+76.5 %
26.0 m³/h
0.60 mmH2O
+50.0 %
0.40 mmH2O
0.4
0.4
0.4
0.4
0.4
0.4
+50.0 %
0.04
0.04
0.04
0.04
0.04
0.04
30.7
-20.9 %
38.8
30.4
-17.2 %
36.7
30
-16.9 %
36.1
30.6
-11.6 %
34.6
