Alphacool
MSI
Eiszyklon Aurora Lux Pro ARGB
MEG Silent Gale P12
27.5 mm
200 g
209 g
600 U/min
1500 U/min
0.7 W
1.4 W
58.3 CFM
56.2 CFM
99.3 m³/h
95.5 m³/h
1.60 mmH2O
2.21 mmH2O
38.0 dBA
22.7 dBA
3.3 V
5.5 V
2.9 V
4.3 V
316 U/min
906 U/min
393 U/min
742 U/min
194 U/min
186 U/min
1499 U/min
1980 U/min
512 U/min
46.0 CFM
+47.6 %
31.1 CFM
24.8 CFM
+15.0 %
21.5 CFM
21.2 CFM
+4.2 %
22.1 CFM
24.1 CFM
+22.6 %
19.7 CFM
78.1 m³/h
+47.6 %
52.9 m³/h
42.1 m³/h
+15.0 %
36.6 m³/h
36.0 m³/h
+4.2 %
37.5 m³/h
41.0 m³/h
+22.8 %
33.4 m³/h
+28.2 %
0.91 mmH2O
0.40 mmH2O
+102.5 %
+62.0 %
0.40 mmH2O
+102.5 %
+28.6 %
0.09 hPa
+100.0 %
+60.0 %
+100.0 %
34.4
-9.3 %
31.2
34.1
-2.0 %
34.8
33.1
-4.3 %
34.6
32.5
-1.8 %
33.1
