Blacknoise
B14x-P-BL PWM ARGB
Light Wings 140 PWM HS
202 g
266 g
250 U/min
1500 U/min
2200 U/min
0.5 W
1.9 W
2.9 W
4.7 W
110.0 CFM
71.7 CFM
186.0 m³/h
121.8 m³/h
2.30 mmH2O
2.30 mmH2O
29.6 dBA
31.0 dBA
4.3 V
3.0 V
335 U/min
565 U/min
154 U/min
556 U/min
1487 U/min
2264 U/min
241 U/min
60.3 CFM
+50.1 %
40.1 CFM
33.2 CFM
+36.2 %
24.4 CFM
32.3 CFM
+43.7 %
22.5 CFM
33.2 CFM
+37.8 %
24.1 CFM
102.4 m³/h
+50.1 %
68.2 m³/h
56.5 m³/h
+36.1 %
41.5 m³/h
54.9 m³/h
+43.7 %
38.2 m³/h
56.5 m³/h
+37.8 %
41.0 m³/h
1.32 mmH2O
+38.6 %
1.83 mmH2O
1.32 mmH2O
+116.4 %
1.01 mmH2O
+65.6 %
1.22 mmH2O
+100.0 %
0.13 hPa
+38.5 %
0.18 hPa
0.13 hPa
+116.7 %
+66.7 %
0.12 hPa
+100.0 %
33.7
-24.3 %
25.5
37.4
-28.6 %
26.7
36.6
-29.8 %
25.7
36
-29.2 %
25.5
  • 556
  • 756
  • 956
  • 1156
  • 1356
  • 1556
  • 1756
  • 1956
  • 2156
