Blacknoise
Alphacool
B14x-P-BL PWM ARGB
Rise Aurora
202 g
180 g
1500 U/min
2500 U/min
0.5 W
2.9 W
110.0 CFM
70.0 CFM
186.0 m³/h
118.9 m³/h
2.30 mmH2O
3.17 mmH2O
29.6 dBA
31.5 dBA
4.3 V
3.0 V
2.9 V
335 U/min
862 U/min
154 U/min
874 U/min
339 U/min
181 U/min
1487 U/min
2775 U/min
1045 U/min
60.3 CFM
+107.8 %
29.0 CFM
33.2 CFM
+36.2 %
24.4 CFM
32.3 CFM
+37.6 %
23.5 CFM
33.2 CFM
+50.7 %
22.1 CFM
102.4 m³/h
+107.7 %
49.3 m³/h
56.5 m³/h
+36.1 %
41.5 m³/h
54.9 m³/h
+37.6 %
39.9 m³/h
56.5 m³/h
+50.7 %
37.5 m³/h
1.32 mmH2O
+115.7 %
1.32 mmH2O
+158.9 %
0.51 mmH2O
1.01 mmH2O
+147.6 %
0.41 mmH2O
1.22 mmH2O
+199.1 %
0.41 mmH2O
0.13 hPa
+116.7 %
0.13 hPa
+160.0 %
+150.0 %
0.12 hPa
+200.0 %
33.7
-19.0 %
41.6
37.4
-8.8 %
41
36.6
-6.4 %
39.1
36
-11.1 %
40.5
