Blacknoise
Lian Li
B14x-P-BL PWM ARGB
UNI FAN SL120 ARGB
202 g
232 g
800 U/min
1500 U/min
1900 U/min
0.5 W
2.9 W
110.0 CFM
58.5 CFM
186.0 m³/h
99.5 m³/h
2.30 mmH2O
1.67 mmH2O
29.6 dBA
31.0 dBA
Silber
4.3 V
2.4 V
335 U/min
412 U/min
154 U/min
98 U/min
1487 U/min
1828 U/min
60.3 CFM
+159.3 %
23.2 CFM
33.2 CFM
+87.7 %
17.7 CFM
32.3 CFM
+104.1 %
15.8 CFM
33.2 CFM
+117.3 %
15.3 CFM
102.4 m³/h
+159.2 %
39.5 m³/h
56.5 m³/h
+87.7 %
30.1 m³/h
54.9 m³/h
+104.1 %
26.9 m³/h
56.5 m³/h
+117.3 %
26.0 m³/h
1.32 mmH2O
+230.0 %
0.40 mmH2O
1.32 mmH2O
+230.0 %
0.40 mmH2O
1.01 mmH2O
+152.5 %
0.40 mmH2O
1.22 mmH2O
+205.0 %
0.40 mmH2O
0.13 hPa
+225.0 %
0.13 hPa
+225.0 %
+150.0 %
0.12 hPa
+200.0 %
33.7
-13.1 %
38.8
37.4
-1.9 %
36.7
36.6
-1.4 %
36.1
36
-3.9 %
34.6
