Cooler Master
Lian Li
Sickleflow 140 ARGB
Uni Fan AL V2 120
28 mm
195 g
240 g
650 U/min
250 U/min
1400 U/min
0.7 W
2.1 W
67.0 CFM
77.3 CFM
113.8 m³/h
131.3 m³/h
2.25 mmH2O
2.97 mmH2O
27.0 dBA
28.7 dBA
Einzelreview
Halbtransparent
5.5 V
3.0 V
2.9 V
599 U/min
762 U/min
495 U/min
749 U/min
297 U/min
198 U/min
1374 U/min
820 U/min
45.3 CFM
+6.4 %
48.2 CFM
28.1 CFM
+43.2 %
40.2 CFM
26.1 CFM
+15.5 %
30.1 CFM
27.0 CFM
+52.5 %
41.2 CFM
77.0 m³/h
+6.4 %
81.9 m³/h
47.7 m³/h
+43.2 %
68.3 m³/h
44.3 m³/h
+15.4 %
51.1 m³/h
45.9 m³/h
+52.5 %
70.0 m³/h
+246.7 %
1.73 mmH2O
+206.0 %
1.53 mmH2O
+104.0 %
1.02 mmH2O
+226.0 %
1.63 mmH2O
+240.0 %
0.17 hPa
+200.0 %
0.15 hPa
+100.0 %
+220.0 %
0.16 hPa
35.5
-11.3 %
31.5
37.2
-21.8 %
29.1
32.8
-7.0 %
30.5
33.5
-10.1 %
30.1
  • 297
  • 497
  • 697
  • 897
  • 1097
  • 1297
  • 1497
  • 1697
  • 1897
