Cooler Master
Sharkoon
Sickleflow 140 ARGB
Silent Storm PWM RGB Fan
195 g
168 g
650 U/min
400 U/min
1400 U/min
1400 U/min
2.6 W
67.0 CFM
113.8 m³/h
121.9 m³/h
2.25 mmH2O
1.47 mmH2O
27.0 dBA
34.7 dBA
Halbtransparent
5.5 V
2.9 V
1.9 V
599 U/min
506 U/min
495 U/min
54 U/min
1374 U/min
1413 U/min
440 U/min
45.3 CFM
+10.3 %
41.1 CFM
28.1 CFM
+13.8 %
31.9 CFM
26.1 CFM
+17.6 %
30.7 CFM
27.0 CFM
+24.4 %
33.6 CFM
77.0 m³/h
+10.3 %
69.8 m³/h
47.7 m³/h
+13.8 %
54.3 m³/h
44.3 m³/h
+17.6 %
52.1 m³/h
45.9 m³/h
+24.4 %
57.1 m³/h
+62.0 %
+42.0 %
+42.0 %
+2.0 %
0.51 mmH2O
+60.0 %
+40.0 %
+40.0 %
0.05
0.05
35.5
-8.2 %
32.6
37.2
-12.1 %
32.7
32.8
-1.2 %
33.2
33.5
-4.2 %
32.1
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
