Cooler Master
Sharkoon
Sickleflow 140 ARGB
Silent Storm PWM RGB Fan
195 g
135 g
650 U/min
400 U/min
1400 U/min
1400 U/min
2.2 W
67.0 CFM
113.8 m³/h
93.6 m³/h
2.25 mmH2O
27.0 dBA
20.4 dBA
Halbtransparent
5.5 V
3.6 V
2.9 V
599 U/min
585 U/min
495 U/min
561 U/min
1374 U/min
1374 U/min
513 U/min
45.3 CFM
+33.3 %
34.0 CFM
28.1 CFM
+44.1 %
19.5 CFM
26.1 CFM
+6.8 %
24.4 CFM
27.0 CFM
+25.4 %
21.5 CFM
77.0 m³/h
+33.2 %
57.8 m³/h
47.7 m³/h
+44.1 %
33.1 m³/h
44.3 m³/h
+6.7 %
41.5 m³/h
45.9 m³/h
+25.4 %
36.6 m³/h
+42.0 %
+22.0 %
+22.0 %
+22.0 %
+40.0 %
+20.0 %
+20.0 %
+20.0 %
35.5
-10.7 %
31.7
37.2
-21.5 %
29.2
32.8
-16.2 %
27.5
33.5
-19.1 %
27.1
  • 561
  • 761
  • 961
  • 1161
  • 1361
