Cooler Master
Fractal
Sickleflow 140 ARGB
Prisma AL-12PWM
195 g
167 g
650 U/min
500 U/min
1400 U/min
1.9 W
67.0 CFM
85.7 CFM
113.8 m³/h
145.7 m³/h
2.25 mmH2O
2.80 mmH2O
27.0 dBA
32.0 dBA
Halbtransparent
5.5 V
4.5 V
2.9 V
3.8 V
599 U/min
443 U/min
495 U/min
269 U/min
1374 U/min
2001 U/min
550 U/min
45.3 CFM
+43.4 %
31.6 CFM
28.1 CFM
+35.5 %
20.7 CFM
26.1 CFM
+25.2 %
20.8 CFM
27.0 CFM
+36.6 %
19.8 CFM
77.0 m³/h
+43.4 %
53.7 m³/h
47.7 m³/h
+35.5 %
35.2 m³/h
44.3 m³/h
+25.1 %
35.4 m³/h
45.9 m³/h
+36.6 %
33.6 m³/h
+62.0 %
+42.0 %
+42.0 %
+22.0 %
+60.0 %
+40.0 %
+40.0 %
+20.0 %
35.5
35.5
37.2
-9.7 %
33.6
32.8
-2.7 %
31.9
33.5
-14.6 %
28.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
