Cooler Master
Alphacool
Sickleflow 140 ARGB
Rise Aurora
195 g
650 U/min
1400 U/min
6.6 W
67.0 CFM
90.7 CFM
113.8 m³/h
154.1 m³/h
2.25 mmH2O
2.20 mmH2O
27.0 dBA
38.4 dBA
Halbtransparent
5.5 V
2.9 V
2.9 V
599 U/min
883 U/min
495 U/min
553 U/min
331 U/min
145 U/min
1374 U/min
2108 U/min
677 U/min
45.3 CFM
+11.2 %
50.4 CFM
28.1 CFM
+5.3 %
26.7 CFM
26.1 CFM
+19.4 %
21.8 CFM
27.0 CFM
+31.5 %
20.5 CFM
77.0 m³/h
+11.2 %
85.6 m³/h
47.7 m³/h
+5.3 %
45.3 m³/h
44.3 m³/h
+19.4 %
37.1 m³/h
45.9 m³/h
+31.5 %
34.9 m³/h
+102.0 %
1.01 mmH2O
+20.0 %
0.60 mmH2O
+42.0 %
+62.0 %
+100.0 %
+20.0 %
+40.0 %
+60.0 %
35.5
-9.9 %
39.4
37.2
-5.1 %
39.2
32.8
-15.9 %
39
33.5
-11.1 %
37.7
  • 331
  • 531
  • 731
  • 931
  • 1131
  • 1331
  • 1531
  • 1731
  • 1931
