Cooler Master
MSI
Sickleflow 140 ARGB
MEG Silent Gale P12
27.5 mm
195 g
209 g
650 U/min
1400 U/min
0.7 W
1.4 W
67.0 CFM
56.2 CFM
113.8 m³/h
95.5 m³/h
2.25 mmH2O
2.21 mmH2O
27.0 dBA
22.7 dBA
Halbtransparent
5.5 V
5.5 V
2.9 V
4.3 V
599 U/min
906 U/min
495 U/min
742 U/min
194 U/min
186 U/min
1374 U/min
1980 U/min
512 U/min
45.3 CFM
+45.6 %
31.1 CFM
28.1 CFM
+30.3 %
21.5 CFM
26.1 CFM
+18.1 %
22.1 CFM
27.0 CFM
+37.2 %
19.7 CFM
77.0 m³/h
+45.6 %
52.9 m³/h
47.7 m³/h
+30.3 %
36.6 m³/h
44.3 m³/h
+18.1 %
37.5 m³/h
45.9 m³/h
+37.4 %
33.4 m³/h
+82.0 %
0.91 mmH2O
+62.0 %
+62.0 %
+62.0 %
+80.0 %
0.09 hPa
+60.0 %
+60.0 %
+60.0 %
35.5
-12.1 %
31.2
37.2
-6.5 %
34.8
32.8
-5.2 %
34.6
33.5
-1.2 %
33.1
