Cooler Master
Alphacool
Sickleflow 140 ARGB
Rise Aurora
195 g
180 g
650 U/min
1400 U/min
2500 U/min
67.0 CFM
70.0 CFM
113.8 m³/h
118.9 m³/h
2.25 mmH2O
3.17 mmH2O
27.0 dBA
31.5 dBA
Halbtransparent
5.5 V
3.0 V
2.9 V
2.9 V
599 U/min
862 U/min
495 U/min
874 U/min
339 U/min
181 U/min
1374 U/min
2775 U/min
1045 U/min
45.3 CFM
+56.2 %
29.0 CFM
28.1 CFM
+14.9 %
24.4 CFM
26.1 CFM
+11.0 %
23.5 CFM
27.0 CFM
+22.4 %
22.1 CFM
77.0 m³/h
+56.2 %
49.3 m³/h
47.7 m³/h
+14.9 %
41.5 m³/h
44.3 m³/h
+11.0 %
39.9 m³/h
45.9 m³/h
+22.4 %
37.5 m³/h
+22.4 %
+2.0 %
0.51 mmH2O
+22.6 %
0.41 mmH2O
+22.6 %
0.41 mmH2O
+20.0 %
0.05
0.05
+25.0 %
+25.0 %
35.5
-14.7 %
41.6
37.2
-9.3 %
41
32.8
-16.1 %
39.1
33.5
-17.3 %
40.5
