Cooler Master
Lian Li
Sickleflow 140 ARGB
UNI FAN SL120 ARGB
195 g
232 g
650 U/min
800 U/min
1400 U/min
1900 U/min
67.0 CFM
58.5 CFM
113.8 m³/h
99.5 m³/h
2.25 mmH2O
1.67 mmH2O
27.0 dBA
31.0 dBA
Silber
Halbtransparent
5.5 V
2.9 V
2.4 V
599 U/min
412 U/min
495 U/min
98 U/min
1374 U/min
1828 U/min
45.3 CFM
+95.0 %
23.2 CFM
28.1 CFM
+58.5 %
17.7 CFM
26.1 CFM
+64.7 %
15.8 CFM
27.0 CFM
+76.5 %
15.3 CFM
77.0 m³/h
+94.9 %
39.5 m³/h
47.7 m³/h
+58.5 %
30.1 m³/h
44.3 m³/h
+64.7 %
26.9 m³/h
45.9 m³/h
+76.5 %
26.0 m³/h
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
+25.0 %
+25.0 %
+25.0 %
35.5
-8.5 %
38.8
37.2
-1.3 %
36.7
32.8
-9.1 %
36.1
33.5
-3.2 %
34.6
