Cooler Master
Arctic
Sickleflow 140 ARGB
P14 PWM
195 g
194 g
650 U/min
200 U/min
1400 U/min
1700 U/min
67.0 CFM
72.8 CFM
113.8 m³/h
123.8 m³/h
2.25 mmH2O
2.40 mmH2O
27.0 dBA
Halbtransparent
5.5 V
3.8 V
2.9 V
599 U/min
395 U/min
495 U/min
481 U/min
1374 U/min
1733 U/min
45.3 CFM
+0.8 %
45.7 CFM
28.1 CFM
+3.7 %
27.1 CFM
26.1 CFM
+1.2 %
25.8 CFM
27.01
27.01
77.0 m³/h
+0.8 %
77.6 m³/h
47.7 m³/h
+3.7 %
46.0 m³/h
44.3 m³/h
+1.1 %
43.8 m³/h
45.9
45.9
+20.0 %
0.60 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+20.0 %
+25.0 %
+25.0 %
+25.0 %
35.5
-13.5 %
30.7
37.2
-18.3 %
30.4
32.8
-8.5 %
30
33.5
-8.7 %
30.6
