Cooler Master
Corsair
Sickleflow 140 ARGB
LL140 RGB
195 g
210 g
650 U/min
600 U/min
1400 U/min
1300 U/min
67.0 CFM
51.5 CFM
113.8 m³/h
87.5 m³/h
2.25 mmH2O
1.52 mmH2O
27.0 dBA
25.0 dBA
Halbtransparent
Halbtransparent
5.5 V
2.9 V
2.9 V
599 U/min
226 U/min
495 U/min
378 U/min
1374 U/min
1319 U/min
45.3 CFM
+0.7 %
45.0 CFM
28.1 CFM
+1.1 %
28.4 CFM
26.1 CFM
+6.5 %
24.5 CFM
27.0 CFM
+2.2 %
26.4 CFM
77.0 m³/h
+0.7 %
76.5 m³/h
47.7 m³/h
+1.0 %
48.2 m³/h
44.3 m³/h
+6.5 %
41.6 m³/h
45.9 m³/h
+2.2 %
44.9 m³/h
+20.0 %
0.60 mmH2O
0.5
0.5
0.5
0.5
+22.0 %
+20.0 %
0.05
0.05
0.05
0.05
+20.0 %
35.5
-0.6 %
35.3
37.2
-0.8 %
36.9
32.8
-3.5 %
34
33.5
-3.7 %
34.8
