Noctua
EK
NF-A14 FLX
Vardar X3M D-RGB
27.5 mm
210 g
210 g
900 U/min
500 U/min
1200 U/min
2200 U/min
2.2 W
68.0 CFM
67.0 CFM
115.5 m³/h
114.0 m³/h
1.51 mmH2O
2.75 mmH2O
19.2 dBA
34.2 dBA
Beige
Braun
Braun
4.6 V
2.7 V
4.2 V
2.3 V
381 U/min
472 U/min
469 U/min
418 U/min
666 U/min
367 U/min
1199 U/min
2161 U/min
53.5 CFM
+46.9 %
36.4 CFM
33.0 CFM
+51.0 %
21.8 CFM
31.7 CFM
+55.5 %
20.4 CFM
30.1 CFM
+57.1 %
19.2 CFM
90.9 m³/h
+46.8 %
61.9 m³/h
56.0 m³/h
+50.9 %
37.1 m³/h
53.8 m³/h
+55.5 %
34.6 m³/h
51.2 m³/h
+57.1 %
32.6 m³/h
0.91 mmH2O
+45.1 %
1.32 mmH2O
0.91 mmH2O
+49.2 %
0.5
0.5
0.30 mmH2O
+103.3 %
0.09 hPa
+44.4 %
0.13 hPa
0.09 hPa
+50.0 %
0.05
0.05
0.03 hPa
+100.0 %
34.2
-12.6 %
29.9
42.6
-20.7 %
33.8
40.8
-30.6 %
28.3
39.9
-28.8 %
28.4
  • 666
  • 866
  • 1066
  • 1266
  • 1466
  • 1666
  • 1866
  • 2066
