Noctua
Alphacool
NF-A14 FLX
Rise Aurora
210 g
900 U/min
1200 U/min
6.6 W
68.0 CFM
90.7 CFM
115.5 m³/h
154.1 m³/h
1.51 mmH2O
2.20 mmH2O
19.2 dBA
38.4 dBA
Beige
Braun
Braun
4.6 V
4.2 V
2.9 V
381 U/min
883 U/min
469 U/min
553 U/min
331 U/min
145 U/min
1199 U/min
2108 U/min
677 U/min
53.5 CFM
+6.2 %
50.4 CFM
33.0 CFM
+23.6 %
26.7 CFM
31.7 CFM
+45.1 %
21.8 CFM
30.1 CFM
+46.7 %
20.5 CFM
90.9 m³/h
+6.2 %
85.6 m³/h
56.0 m³/h
+23.6 %
45.3 m³/h
53.8 m³/h
+45.0 %
37.1 m³/h
51.2 m³/h
+46.7 %
34.9 m³/h
0.91 mmH2O
+11.0 %
1.01 mmH2O
0.91 mmH2O
+51.7 %
0.60 mmH2O
+42.0 %
0.30 mmH2O
+170.0 %
0.09 hPa
+11.1 %
0.09 hPa
+50.0 %
+40.0 %
0.03 hPa
+166.7 %
34.2
-13.2 %
39.4
42.6
-8.0 %
39.2
40.8
-4.4 %
39
39.9
-5.5 %
37.7
  • 331
  • 531
  • 731
  • 931
  • 1131
  • 1331
  • 1531
  • 1731
  • 1931
